mounting rs body kit
Old Sep 16, 2008 | 03:35 PM
01Pontiac's Avatar
Default mounting rs body kit
I'm considering buying a rs body kit from a guy on here, but he is missing some of the mounting brackets.
how can I mount it if I can't find any more of them? A friend of mine who used to have a 98Z28 with the kit said that you can just screw it in and use some two way tape, but that seems rigged up and I don't want it to look like crap
Old Sep 16, 2008 | 03:51 PM
J&J Motorsports FL's Avatar
You might be able to buy the brackets from GM. If not double sided body tape and some black push pins should do the trick. That is how most aftermarket kist are attached. It will look fine.
Old Sep 18, 2008 | 12:32 AM
ZexGX's Avatar
Found some for sale on a V6 forum: http://forum.camarov6.com/showthread.php?t=93335
Old Sep 18, 2008 | 01:00 AM
Camaro Ryder KV's Avatar
ill sell you my factory rs sides and rear that have all the mounting tabs for less then you are buying them from the other guy! PM me
Old Sep 19, 2008 | 08:32 PM
noobsauce's Avatar
your friend seems to know an awful lot about things....... you should just listen to him.....he would never give you bad advice or settle for anything less than the best
