Installing gauges
Old Dec 19, 2001 | 02:15 PM
Phil99TA's Avatar
Default Installing gauges
I'm about to install two interior gauges that need to be connected to a switched 12V power source. I currently have a shift light installed. Can I tap into the same wire the shift light is using for power (under the dash), or should I find a different wire source for each gauge?
Phil <--electronics dummy
Old Dec 19, 2001 | 03:08 PM
Jim98TA's Avatar
Default Re: Installing gauges
You should be able to tap them all into the same source. The easiest thing is to find an open "ign" spot in the fuse box. Just make sure you fuse each accessory individually.
