Dimmer wire behind radio?
Old Dec 25, 2001 | 09:33 PM
Sears's Avatar
!Dial-up Director
Default Dimmer wire behind radio?
What wire is for the dimmer behind the radio?
Thanks,
Justin <img src="graemlins/gr_xmas.gif" border="0" alt="[santa]" />
Old Dec 26, 2001 | 10:02 AM
Jay B4C's Avatar
Default Re: Dimmer wire behind radio?
One the plug with a yellow,orange,black,brown, and gray. wire it should be either the brown or gray. One is the illumination and the other is the dimmer. GM used both. the easiest way to check is with a vot meter or a test light. ground one side of the tester and then probe the wires with parking lights on. The illumination wire will have constant voltage while the parking lights are on, and the dimmer will varywith the dimmer switch next to the headlight switch.
Old Dec 29, 2001 | 10:29 PM
Sears's Avatar
!Dial-up Director
Thanks Jay!
