? ABOUT ET STREETS
Old Jan 6, 2002 | 09:13 PM
ROBS SS's Avatar
Default ? ABOUT ET STREETS
WAS WONDERING WHAT IF I COULD RUN A 26X11.5X16 ON MY SS OR DO I HAVE TO GET A 26X10.5X16....I KNOW THE 15" ET STREETS RUN SMALL....THEY SAY 26X10.5X15 IS REALLY ONLY LIKE 8.8 INCHES WIDE WERE THE SLICK IS A TRUE 10"....WANT THE BIGGEST TIRE POSSIBLE WITHOUT AND ALTERCATIONS...I AM USING 16" WHEELS FROM A FORMULA....THANKS GUYS!
Old Jan 6, 2002 | 09:21 PM
BIGBOS's Avatar
Default Re: ? ABOUT ET STREETS
When I was thinking about going with salad shooter rims I was going to go with
26"x10.5x16
It will work fine, just experiment with the PSI
Old Jan 6, 2002 | 10:48 PM
ROBS SS's Avatar
WHAT WILL WORK FINE! THE 11.5 OR THE 10.5....I AM TRING TO GET AS MUCH TIRE ON THE CAR AS POSSIBLE DUE TO I HAVE A 3400 COVERTER AND AM HITTING A 150 SHOT OUT OF THE HOLE.
Old Jan 6, 2002 | 11:13 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Hi...
1- No all caps.
2- We have in the past run 26x11.5x16's on stock 16x8 rims no problem. My friend sprayed out of the hole and used to go 11.4 with a 3700 lb raceweight.
3- I switched to 15x10/15x11.5x26 ET Streets and cut a 1.53 with this setup back on 12/9.
Old Jan 7, 2002 | 04:34 AM
ROBS SS's Avatar
thanks for the reply...ill be ordering the 11.5's then....anyone know a good place to bye et streets
Old Jan 7, 2002 | 07:07 AM
BIGBOS's Avatar
John will I be able to put 26"x11.5x15" ET DRAGS on my 15x7 rims??
Do they make ET DRAGS in that size??
Old Jan 7, 2002 | 03:01 PM
BIGBOS's Avatar
Yea, I have et streets mounted on the rims that are brand new, so I will work with those for awhile.. <img src="gr_stretch.gif" border="0">
Old Jan 8, 2002 | 12:37 AM
Chris Spiess's Avatar
Not listing in the catalog. Go here for available sizes.
 Michael S. Palmer
Old Jan 8, 2002 | 12:39 AM
LS1Tech Co-Founder
Bos you just bought ET Streets right? Work with those first, I cut a 1.53 with mine.
For you q, try www.mickeythompsontires.com
