only 1st gear
Old Oct 19, 2008 | 07:45 PM
Ari G's Avatar
Default only 1st gear
I bought a trans broken,dosenīt shift from 1st gear,what is the common cause of that?Need to know what to look for when tearing apart
Old Oct 20, 2008 | 12:20 AM
performabuilt's Avatar
LS1Tech Sponsor
What kind of trans is it ?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Oct 20, 2008 | 03:41 AM
Ari G's Avatar
sorry 4l60e
Old Oct 20, 2008 | 07:51 PM
Ari G's Avatar
Iīve began to tear ir appart,can you tell me what to look for?
Old Oct 21, 2008 | 05:10 AM
FLT's Avatar
FLT
Sounds like a locked up low roller if I had to guess.
Old Oct 21, 2008 | 09:15 AM
LS1Tech Sponsor
As Vince mentioned I would look at the Low roller clutch but usually rather than just first when is locked you will get a bind up brakig effect when its time for the 1-2 shift to ocur, Also look at the 1-2 Shift valve
Thing is was the fact the shift was being commanded ever verified ?
Was the speedo working on the car it came out of?
Take some pictures of what you see inside and post them up maybe we will see something .
__________________
Call 888-744-6542
