Aftermarket AL trans pan
Old Sep 15, 2003 | 11:09 PM
Cheatin' Chad's Avatar
Default Aftermarket AL trans pan
Which ones are you guys using?
Where were they made?
How much did it cost?
I'd like to get one for around $100 but I am not going to buy one made in Chiwan or some other backwoods commie country.
Old Sep 16, 2003 | 09:07 AM
Jorday's Avatar
Default Re: Aftermarket AL trans pan
I wantded to get one too, but the problem was they were well over 100 bucks. I didn't really want to spend that much on a trans pan, so I just bought the biggest trans cooler I could.
Old Sep 16, 2003 | 12:04 PM
GreekZ's Avatar
Im using the B&M steel trans pan Jegs sells for
$48 bucks. It holds 3 extra quarts and comes
with a built in drain plug and gasket. Im happy with mine, no leaks and the chrome pan looks nice!
BTW, it's advertised for 700R4 transmissions but
works on 4l60E's too
Old Sep 16, 2003 | 06:28 PM
ttt
Old Sep 16, 2003 | 07:13 PM
jfm's Avatar
jfm
I used the GM truck pan with a drain plug,holds 1 extra quart.With the new filter kit cost under $80.
Old Sep 17, 2003 | 06:28 AM
Kevin Winstead's Avatar
You can get the TCI 2 xtra quart deep aluminum pan from Jegs for $119.99 and it's Made in the USA.
Kevin
