Help!
Old Oct 27, 2008 | 02:53 PM
quickneSS's Avatar
Post Help!
Okay i need some advice on what STR i should go with on my new stall. I was thinking of going with a 3800. The problem is i dont want it to be to loose. I like those highway runs every now and then! should i stay around a 2.0 STR. Need to buy a new tranny and stall ASAP...sorry, prolly could of searched but dont have that much time with work and school
TIA,
Jon
Old Oct 27, 2008 | 03:11 PM
FTICONVERTERS's Avatar
LS1Tech Sponsor
Jon,
For driveability on the street a 3800 with a str of 2.0 to 2.16 is very driveable.The higher the str the harder the converter hits the tires and the looser it drives. But in many instances the str being a little lower will actually outrun the higher str because the car will get better tractionresulting in better 60'. If You have any more questions feel free to call Greg at 1-866-726-8358.
Thanks,
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Oct 27, 2008 | 07:59 PM
Firechikn's Avatar
From what I've heard, you can't actually pic which str you get. Reason being a certain stator and turbin = X stall which = X str. I'm sure the torque from engine to engine will vary this, but you can't just say, " I want a 4500 stall with a 2.0 str ". Is this correct? I'm no converter manufacturer.
Old Oct 27, 2008 | 09:58 PM
quickneSS's Avatar
thanks for responses guys...anyone else c'mon guys...best stall for TR224 cam & 373's...personal experiences? gonna purchase combo tomorrow let me know
TIA
Old Oct 27, 2008 | 10:25 PM
TurboAv's Avatar
If that's the case you would be able to build it with the correctly chosen parts to get you to the STR you desire.
Old Oct 28, 2008 | 07:47 AM
LS1Tech Sponsor
We can build your converter to the str you want within reason. Certain str's work better with different combinations.That is why I custom build each converter for each application.
Thanks,
Greg
__________________
1-866-726-8358
FTIPerformance.com
