Experiencing Intermittent Lockup
Old Nov 26, 2008 | 11:31 PM
richard head's Avatar
I believe that it has cured mine as well. Car woke up a lot from doing this, maybe it had a stall in it all along and I just didn't even know about it.
Old Dec 3, 2008 | 06:50 PM
Mister Peebody's Avatar
Default The Verdict Is In...
Got the car to the tuner today and had him adjust the misfire tables, as suggested. The Verdict - The converter locks and unlocks as it should now. I drove the car about 100 miles after the adjustment was made and all is well.
Thank you doesn't scratch the surface of my gratitude, but Thank you !
Old Dec 3, 2008 | 08:00 PM
blakern's Avatar
Cool man. glad u got it fixed, I know how annoying it is to drive when the cars acting like that.
Old Dec 3, 2008 | 11:02 PM
I put the MAF sensor back in mine after this seemingly fixed my problem and it started acting up again, so I'm back in SD mode with a new Edge 3000 stall in the mail. Has yours acted up since you posted that? If you do start to have problems just get rid of the MAF and run the car in SD because, for whatever reason, it seems to help dramatically and I know the MAF is used in torque calculations so it does have a strong impact on the way the computer handles it.
Old Dec 13, 2008 | 02:46 PM
69_YENKO's Avatar
good info, im going to have to try this. as im having the same intermittent unlock/lock problem when driving at highway speeds, even with the Cruise control on.
Old Dec 13, 2008 | 05:44 PM
calongo_SS's Avatar
Have you completely tuned out misfire detection? I used to run a MAF and had no problems with misfire detection completely off.
Old Dec 14, 2008 | 09:21 PM
Yeah, I had missed one table and went back and got it and it helped, but again not completely fixed.
Old Jan 27, 2009 | 04:37 PM
camaroIroc's Avatar
would these tuning changes have any effect on a non-ecm controlled 700r4? i think i sound retarded, just wondering..
Old Jan 27, 2009 | 05:26 PM
calongo_SS's Avatar
yup, you sound retarded, lol
just busting *****, but no they shouldn't. do you have a lock up switch?
Old Jan 27, 2009 | 05:39 PM
camaroIroc's Avatar
yea. i think my tcc valve is sticking though, solenoid is good.. wiring is good..
Old Jun 19, 2009 | 04:46 PM
76LQ9TA's Avatar
Do you know what values your tuner used? If the values are too high do you lose mis-fire detection capability? I'm having the same problem with a LQ9/4L80E. No codes displayed. If it is detecting a mis-fire, why isn't a code displayed?
Old Jun 19, 2009 | 05:51 PM
  #32
performabuilt's Avatar
LS1Tech Sponsor
A code is not always displayed for missfire only if it becomes severve . Randon missfires generally do not set a code
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Apr 14, 2011 | 04:42 PM
  #33
Phil'sC5vette's Avatar
very good thread.
You can have the check engine light flashing on and off, but not throw a misfire code.
