4l60e
Old Nov 8, 2008 | 06:56 AM
CrashnBurn's Avatar
Exclamation 4l60e help!!!
Car is having misfire issues and while diagnosing that i have twice driven around the block about a 1/2 mile. Each time i opened the hood to find a puddle of tranny fluid (from the dipstick tube) on the passenger side of the intake. The fluid is extremely dark. What is causing it to spew out the dipstick tube? Would changing the fluid help? It had beed slipping at half throttle just prior to being garaged due to misfire problem.
Old Nov 8, 2008 | 11:10 AM
performabuilt's Avatar
LS1Tech Sponsor
If the trans fluid is dark and has a burnt smell there is likley a trans issue. The fuild out of the dipstick could either be from overheating from slipping or a converer issue and or a stopped up vent tube.
I would certainly drop the pan and see whats in it.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Nov 8, 2008 | 11:20 AM
the_merv's Avatar
Veteran: Air Force
You burned it up and some Clutch Material is probably blocking some ports off in the Valve Body.
