Flywheel bolts
Trans guys what length and size bolt needed when installing the TCI 399754 flywheel,, in a 4L60E, and does it change the postion of the converter against the pump since the flywheel is thicker ??
From: Poway, Ca. where GOD and the sun always shines
I'm not sure about the position of the flexplate, however the unit should have come with new bolts.
If yours did not, MAKE SURE YOU USE A GRADE 8 BOLT.
SteveC
SteveC
