How much line pressure?
Old Sep 21, 2003 | 07:41 PM
whitt1's Avatar
Default How much line pressure?
I just installed a TCI stand alone computer on my supercharged Tahoe.With lots of adjustability comes lots of options and lots of questions.How much line pressure can I safely run on a 4L60E,how quick should I make the shifts and where should I lockup the converter?The computer has a performance and economy switch so I don't have to live with my perfomance settings riding around town.
Old Sep 22, 2003 | 01:04 PM
Jorday's Avatar
Default Re: How much line pressure?
I don't know where as far as the most line pressure you can safely run. I would just be careful increasing the line pressure too awful much.
Old Sep 22, 2003 | 01:58 PM
JoSeY's Avatar
i run 120psi
Old Sep 23, 2003 | 08:23 AM
Kevin Winstead's Avatar
As you're driving down the highway, you shouldn't need much over 100 psi, since there isn't much of a load on the clutches at that point. I typically like to see the line pressure rise very quickly on blown applications, so you'll want a fairly steep slope on the line pressure curve. You should "zero out" the curve at WOT. That is max. pressure on the T-Com unit.
Kevin
Old Sep 23, 2003 | 02:00 PM
A BAD T/A's Avatar
Actual GM specs:
In Drive, Park or Neutral 50-189psi.
Reverse: 67-324psi
Experts consider any setting over 200 @WOT to be avoided.
