Bolt-on Autos: Chime in please
Old Nov 27, 2008 | 10:21 AM
SOM WS9's Avatar
All stock internals with an Edge 3,400 stall and mine shifts at 6,100 RPM 1-2 and 2-3. Crosses the traps at 6,500 or so, definitely out of the power band so I need a bit more tire. Worked well enough for a 11.93 pass on a 1.53 60'.
Old Nov 27, 2008 | 10:26 AM
GatorFan08's Avatar
My car is full bolt ons and it falls on its face after 5500. so I have it set to shift at 5700
Old Nov 27, 2008 | 10:55 AM
richard head's Avatar
Internals Stock? No reason at all to change WOT shift points. Leave 'em the **** alone lest ye bend a pushrod.
Old Nov 27, 2008 | 12:45 PM
JonCR96Z's Avatar
What kind of times are you running at the track?
Here's my dyno graph with only lid/catback before and after tuning.
While it might be making less power past 5500 it's definitely not falling on its face.
Old Nov 27, 2008 | 01:30 PM
RevGTO's Avatar
Pontiacerator
Right. And shifting too early - especially on 1-2 - puts you too low in the rpm range in the next gear ... unless your converter makes up the difference.
Old Nov 27, 2008 | 07:19 PM
01ssreda4's Avatar
Factory shift points are 6000, you should try 6400-6600.
let me talk with my tuner to double check that. does a tr224 .564 114 make power past 6000?
Old Nov 28, 2008 | 12:53 AM
JonCR96Z's Avatar
Exactly. Losing 5hp after 5500 is better than losing 15 at below 4000. It's all about the average power, not the peak.
