Question about the 200 and 700r4
Old Nov 23, 2008 | 07:53 PM
ProStreet_632's Avatar
Default Question about the 200 and 700r4
Does the 200 4r and the 700r4 have the same mounting position on the crossmember? Or is 1 longer than the other?
Old Nov 23, 2008 | 08:20 PM
performabuilt's Avatar
LS1Tech Sponsor
The 700r4 is longer than the 2004r
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Nov 24, 2008 | 12:18 AM
jakeshoe's Avatar
Yea but the mounting position is further back on the 200-4R, which I believe was the question.
Old Nov 24, 2008 | 07:02 AM
Thanks guys, thats what I needed
Old Mar 4, 2022 | 05:51 PM
Nick912's Avatar
Also just measured, piston work surface height is .610”. Is this in spec with the oem forward pistons?
edit: wrong thread, please discard.
Old Mar 18, 2022 | 09:05 PM
matermark's Avatar
The 2004R can usually be swapped into (dimensionally) cars that had TH350's if you're looking for benefits of overdrive, and the 2004R has a little more OD than the 700R4... a very little bit more... I think 0.67:1 (or was it .68?) vs 0.70:1.
