Vibration in car at high speeds
Old Nov 27, 2008 | 10:01 PM
Blk_Ws6's Avatar
Red face Vibration in car at high speeds
What could this be fellas ever since I had my tranny rebuilt when I get over 120 it vibrates real hard trying to find out what this could be anyone?
Old Nov 28, 2008 | 03:02 AM
redcard2k7's Avatar
could possibly be not the tranny at all...could be the alignment and balancing on your tires
Old Nov 28, 2008 | 04:54 AM
Randy WS6's Avatar
Could be, slack in the tail shaft bushing, between the yoke & housing . In my case it was the pinion angle.
Old Nov 28, 2008 | 08:35 AM
crzytown69's Avatar
or the ds if its steel
Old Nov 28, 2008 | 12:20 PM
cals400ex's Avatar
maybe you could rotate the driveshaft 180 degrees after you unbolt it and then bolt it back up. it is possible that the torque converter to flexplate is not perfectly flush either.
