Tunning
Old Dec 1, 2008 | 04:41 PM
CayenneRedV6's Avatar
Default Tunning
I'm going to do some work to my car including 3000 stall TC and a shift kit and then I'm going to have it tuned. What exactley do I want my tuner to do in regards to the transmission. I'm a little nervous because I don't know anything about the computer side of a transmission. Thanks.
Old Dec 1, 2008 | 10:34 PM
Just wondering what I need to tell this guy I want done. Thanks.
Old Dec 1, 2008 | 11:23 PM
performabuilt's Avatar
LS1Tech Sponsor
I cant tell you all but these things should be done
1-remove the test for PO751 and PO757 Many tuners dont do this t should allways be done with high stalls
2-Set lockup to only happen in 4TH above 45 mph
3- max out the TCC duty cycles
4-if you have a shift kit leave the line settings stock you probably have enough
5- 0 out adaptives
6-Remove torque management
7-max out misfire
Hope this helps
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Dec 2, 2008 | 11:28 AM
That helps I just wanted an idea of what he needs to do so I sound a little better informed when talking to him to make sure he's going to do what he's supposed to. Thanks.
