TH400 overdrive unit
Old Dec 15, 2008 | 05:08 PM
johnLs1camaro's Avatar
Default TH400 overdrive unit
well i have had so many problems with my 4l60e i was looking at putting a TH400 in.. well i drive the car a lot and i was searching and saw they have a overdrive unit that you can put on the tailshaft, they look pretty cool.. i was wondering if anyone else has one, and have you had any problems with it..
Old Dec 15, 2008 | 05:27 PM
Circle-D's Avatar
I would recommend getting a 4L80. You would get OD and a lock up converter and computer controlled. Probably cheaper than a built 400 with the bolt on OD.
Chris
Old Dec 15, 2008 | 05:38 PM
yeah, i looked at also.. so now what would i have to change on the 98 pcm to make the 4l80 work
i also have a th400 laying around that why i asked
Old Dec 15, 2008 | 05:48 PM
ChocoTaco369's Avatar
Tech Resident
A 4L80E would be a lot cheaper as well and you'd go faster. A TH400 and a Gear Vendors Overdrive would consume as much parasitic loss as two transmissions - you'd lose a huge amount of power going that route. That and a GVO is very expensive by itself. The 4L80E would be more efficient, a lot cheaper and just as strong.
