m6 aluminum ds in a4
Old Dec 21, 2008 | 01:20 PM
fly pantera's Avatar
Default m6 aluminum ds in a4
has anyone install a stock aluminum driveshaft from a m6 into a a4.
is it a direct swap?
is there any gains,or downside?
which is stronger?
has anyone weighed them?
depending on the results i might swap one over from my m6 to my a4 listed in sig
Old Dec 21, 2008 | 01:40 PM
camscam02's Avatar
its the same
Old Dec 21, 2008 | 01:43 PM
its the same as in......
Old Dec 21, 2008 | 02:10 PM
camscam02's Avatar
the same driveshaft is used in the a4 and m6 cars, no difference in strength, weight, length, or yokes.
Old Dec 21, 2008 | 02:26 PM
im talking about the steel ds to aluminum ds,if there is no gains then I will not swap them over
the_merv's Avatar
Veteran: Air Force
It will go in without a problem. The Aluminum one is smoother at higher speeds, weighs around 12 lbs.
Old Dec 21, 2008 | 06:50 PM
crzytown69's Avatar
trust me get rid of the steel trash i broke two tail shafts before i figured out that the steel ds is like a jump rope when your pulling some hard rpms all kinds of vibs
