Separating 4l60e from motor?
Old Dec 28, 2008 | 09:26 PM
Camaro396's Avatar
Default Separating 4l60e from motor?
Anyone have any tips on how to get this turd off my motor? All bellhousing bollts, converter bolts, and harnessess are disconnected. I have soaked the dowl pin areas in WD-40 for the last two days, and this thing just will not break away from the block, and I can't really come up with any good areas to try to pry with a BFS. Any tips?
Old Dec 28, 2008 | 09:55 PM
heymoej's Avatar
ratchet strap the tail to your rear end & ratchet & pry a little at a time until she pops off.........
make sure all bolts are out first !
Old Dec 28, 2008 | 10:05 PM
9000th01ss's Avatar
I use a 3' crow bar right where you removed the plastic dust shields. pops right off.
Old Dec 28, 2008 | 10:10 PM
tptransmission's Avatar
Closed ex-Sponsor Account
If you have all the bolts out included the one on the top center then a little prying is in order.
Old Dec 28, 2008 | 10:14 PM
Camaro396's Avatar
Yeah, they are all out. I guess after 90k miles it just doesn't want to leave without a fight!
Old Dec 28, 2008 | 10:22 PM
The only saving grace is that the bellhousing is replaceable should it incidentally get cracked.
Old Dec 28, 2008 | 10:23 PM
jsteele90's Avatar
just push up and down on the tailshaft hard as **** it will come loose. worked for me
Camaro396's Avatar
Oh I don't care what happens to this pile, its broke, and I just want it out. I have my TH350 waiting to go in.
Old Dec 28, 2008 | 10:24 PM
Camaro396's Avatar
Tried that. Realized how badly I need new motor mounts.
Old Dec 28, 2008 | 10:34 PM
grey95buick's Avatar
LMFAO.
Old Dec 28, 2008 | 11:13 PM
FLT's Avatar
FLT
You forgot to curse and swear at it while doing so. These things can be tough and all the above advise is needed in cases such as yours. Vince
Old Dec 28, 2008 | 11:45 PM
Camaro396's Avatar
Well thanks guys. I'm about to go back out in the garage and crawl back under and try again.
Old Dec 28, 2008 | 11:59 PM
jsteele90's Avatar
wrap a chain around it and the other end to a truck yank that bitch out of there
Old Dec 29, 2008 | 12:01 AM
01ssreda4's Avatar
ha ha good luck. mine gave a little fight but not that much.
Old Dec 29, 2008 | 01:19 AM
Camaro396's Avatar
I truely have no idea what to do at this point. For the last three days I've beat on, pounded on, wiggled up and down, side to side, and pryed on this thing, and it will just not budge. Ive double, tripple, and quadruple checked that EVERY bellhousing and converter bolt is out. I don't know what else to do.
Old Dec 29, 2008 | 03:55 AM
TireSm0ke's Avatar
Pull the driveshaft (If you havent already) and youll need to pull it back from the motor. Did you get the bolt up top?
Old Dec 29, 2008 | 10:35 AM
9000th01ss's Avatar
Have a flatbed come haul it to a transmission shop.
Seriously.
THREE DAYS! I don't know how many hours or what tools you're working with but 3 days is 71.8 hours too long.
Not trying to be a dick but come on, let my comments **** you off and go out there remove the damn thing.
Old Dec 29, 2008 | 10:37 AM
Camaro396's Avatar
Yeah, your telling me! I would, but the car has no front or rear suspension on it at the moment.
Old Dec 29, 2008 | 10:44 AM
Benner's Avatar
STOP!!! Hammer Time!!!
Old Dec 29, 2008 | 10:47 AM
Camaro396's Avatar
I've beat the **** out of this thing. BFH, crowbar, kicked it, punched it, hung from it, nothing works. I know all bolts are out. It doesn't make sence.
