TH400 swap..Torque converter question
OH! One more thing...Driveshafts. I heard that an M6 driveshaft will fit into an F-body with a TH400 swap no shortening or lengthening required. Is this true? And if so, which size tailshaft would I need for this to be done?
Greg
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
things you have to do are in the stickie under FAQ.
You will need a tci flexplate the sfi one that has the sbc patter with it or have a vender built you a t400 stall that bolts up to a ls1 flexplate if you are putting down any power buy the flexplate or yours will warp like mine and break
1 YOU WILL HAVE TO HAVE A DRIVESHAFT MADE COST ME $350
2.IF YOU DO RMVB THEN YOU WILL NEED A B&M RATCHET SHIFTER
3.STALL I WENT WITH A NEAL CHANCE
4.TRANNY T400 CROSSBRACE THAT OTHER CRAP OF USING A 6SPEED ONE DOES NOT WORK OR PUTTING SPACERS F THAT I CALLED YANK AND BOUGHT ONE OF THERE TRANNY CROSS BRACES.
5. CALL FRANK AT PERFORMABUILT ON THE T400 IT ROCKS.
