93z28 auto question please help
Old Jan 1, 2009 | 04:51 PM
93z28_6spd's Avatar
Default 93z28 auto question please help
why does my tranny always seem to take off in 2nd gear.. the only way i can get it to take off in 1st is to shift it out of drive, like reverse, or Neutral.
how can i eliminate this pain in the A%%
thanks
Old Jan 1, 2009 | 08:02 PM
93z28_6spd's Avatar
to the top.. need some help
Old Jan 1, 2009 | 09:26 PM
FLT's Avatar
FLT
Sounds like a sticky TV valve in the valve body. The transgo kit addresses this. Might be something to consider. Vince
Old Jan 1, 2009 | 09:42 PM
93z28_6spd's Avatar
thanks for your help.. .i didnt know if it was like the newer ones that ran partially off of TPS and such. . could the TPS and anything else have anything to do with it.. and is there anything i could try besides going internal of the tranny..
thanks
Old Jan 1, 2009 | 10:04 PM
FLT's Avatar
FLT
No your trans uses a TV cable to control line pressure and also with this cable a governor is used for shift timing. The TPS will not effect the issue you are having. I'm pretty sure it is internal. Vince
Old Jan 2, 2009 | 09:05 AM
93z28_6spd's Avatar
