TransGo HD2 Kit Impressions
Probably end up blowing the snap ring out of the drum one day, but I also upgraded the 3-4 clutch when I put the kit in it, so who knows.
I bought this kit a few days ago to help extend the 65Es trans life behind the Circle D 4C thats going in. I pulled the trans out today and will be tackling the kit tomorrow.
Leaving any amount of TM in is going to hurt performance at some unpredicted point.
Shift kits and TM do not belong in the same car IMO.
Good luck on that.
First off there is no upgraded reverse drum, and if there was, and you used it with a stock reaction shell, the reaction shell can still damage the drum correct?
So the answer is upgrade the reaction shell. And run a stock reverse drum, you'll never break it.
