tranny or rear?
Old Jan 2, 2009 | 04:52 PM
blake110106's Avatar
Default tranny or rear?
well today on my way home from town it started acting up. From a dead stop it was like I was like i had the E-brake on and from second on it was fine. when I pulled in the drive way I put it in reverse and its the same thing as first. I jacked it up to check everything and see how it did with the tires free. Well in reverse the will dont move. Give it gas and at 1800rpm or so they move but when I let off the gas they immediately stop. Same thing if I pull it all the way to first.(yes mine goes all the way) if I put it in OD, D , and 2nd they spin free but sometimes its makes a clanking sound from the rear and the pass side tire almost stops when it does it and once the driver side stopped and the pass side keep turning. the wheels also turn in N like its in drive.
is it both or just one of the two? need input. hope you can understand what I typed cause Im kinda mad and i hate typing. Sorry if you cant guys!
Old Jan 2, 2009 | 07:31 PM
performabuilt's Avatar
LS1Tech Sponsor
Well if it locks the wheels up in only manual low and reverse there is some issue with the trans as gear position would have no effect if it was the rear
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jan 2, 2009 | 07:35 PM
yeaim pretty sure the the trans. Its still shows it full of fluid and isnt discolored or doesnt small. I just had it redone back in late sept and it only had a 90 warranty LMFAO I might be putting a trans on layaway from you guys soon!
Old Jan 2, 2009 | 10:46 PM
LS1Tech Sponsor
Sorry for your misfortune its likely a mechanical hard part failure and we will be happy to do that
__________________
Call 888-744-6542
