temperature of mi trany
Old Jan 12, 2009 | 03:25 PM
mandreake's Avatar
Default temperature of mi trany
i have a 3600 stall, 18k gvw cooler, the temp is 180 in stop and go traffic
but burning tires whit linelock on the track ,after the second pass the temp is 210 is that normal or is too high.
Old Jan 12, 2009 | 03:39 PM
performabuilt's Avatar
LS1Tech Sponsor
Whats the temp outside and where are you measuring the temp from? But yes the temp will jump after a few burn outs and while 210 is warm its not excessively high the 180 in stop and go is also fine
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jan 12, 2009 | 03:44 PM
mandreake's Avatar
i have temp trans gauge from autometer and outside is about 85 degrees
Old Jan 12, 2009 | 03:51 PM
LS1Tech Sponsor
That sounds fine over all. When I ask about gauge hwere does it take its reading, If it takes it from the pressure port it will be a little higher than the real average temp
__________________
Call 888-744-6542
Old Jan 12, 2009 | 04:06 PM
mandreake's Avatar
i ask my mechanic he said ,right after the cooler
Old Jan 12, 2009 | 04:08 PM
LS1Tech Sponsor
Still the temps are reasonable , With a larger cooler you could go lower. But there is not danger in the range your in
__________________
Call 888-744-6542
