Too much tranny fluid
Old Jan 15, 2009 | 06:47 PM
texas99Z28's Avatar
Default Too much tranny fluid
Is it true that over filling the tranny with fluid is that bad for it? How badly will it damage the seals, etc. Recently had my tranny rebuilt, and found out about 3 weeks later the shop over-filled with fluid.
Old Jan 15, 2009 | 08:04 PM
BSmith's Avatar
What is overfilled? 1 quart probably won't hurt it. 5 probably will.
Old Jan 15, 2009 | 08:37 PM
texas99Z28's Avatar
2 quarts over
Old Jan 15, 2009 | 11:12 PM
tptransmission's Avatar
Closed ex-Sponsor Account
It depends on a few different variables, such as the pan your are running ,what's the operating temperature of the transmission ETC.. To keep it somewhat short, the production fluid level accounts for expansion as the temperature of the oil increases. So at very hot temperatures customer will not experience fluid expulsion from the vent, oil foaming/pump cavitating. If you over fill the transmission the oil will eventually get in the rotating parts. They then act like a blender (in simple terms), causing foaming of the fluid and potentially pump cavitation. As the temperature increases, so does the oil level.
