AWD 4l65e to 2wd
Old Jan 15, 2009 | 10:23 PM
chevyloverjp's Avatar
Default AWD 4l65e to 2wd
i just picked up a motor and trans from a 2003 Silverado SS and want to use it in my nova. Can i just add a tail shaft housing to make rear wheel drive or do you need to replace output shaft and tailshaft housing. Any info or suggestions.
Old Jan 15, 2009 | 10:30 PM
performabuilt's Avatar
LS1Tech Sponsor
You will need to remove and replace the tail shaft along with the housing the shaft is too short
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
