Tough time choosing a converter
Old Jan 16, 2009 | 09:14 PM
jhubbs's Avatar
Default Tough time choosing a converter
I snagged a low mile 5.3l engine a while back to swap into my '84 Camaro. I've been collecting parts to build it up a little before I drop it in. My setup will be:
Victor Jr carb intake
750cfm Proform DP
MSD 6010
TSP224r
1.75" primary longtubes
PAC 1218's
Th350
3.23 rear
315/35/17 rear tire
Maybe a small nitrous shot at some point
Now I'm having troubles choosing a converter, mainly what stall to get. The guy who built my trans has a JW Performance 10" 3600 converter built for nitrous. Would a 3600 stall be too high for my combo? I searched around and can't really find anyone using my particular setup.
Old Jan 17, 2009 | 02:09 AM
01ssreda4's Avatar
call andre at edge converters (google it) and see what he recommends. very nice guy to deal with.
Old Jan 17, 2009 | 11:44 AM
Yank's Avatar
Go to our website www.converter.cc and look at the converter guide
Here is the link
http://www.converter.cc/converter_selector/
Old Jan 17, 2009 | 01:57 PM
Circle-D's Avatar
Are you building a street toy or plan on multiple trips to the track? Would you lean to better performance or better street manors? You mentioned the TH350 - non-lock up?
Chris
Old Jan 17, 2009 | 05:38 PM
jhubbs's Avatar
It'll mostly be street driven, but will see some track time (maybe 5-10 times a season). I'd like it to have ok street manners so it's not a total PITA to drive around town. If I had to choose, though, I think I'd go with a little more performance than better manners. The trans is a non-lock up, 9" tail TH350 with this street/strip rebuild kit from Pro-built, which includes a Trans-go shift kit.
According to the Yank website, I should have around a 3600 stall.
Old Jan 17, 2009 | 06:26 PM
Circle-D's Avatar
I would suggest a converter in the 3400-3600 range as well. The Circle D "3C" should be perfect for you. It uses the C series stator which gives you good street manors and a nice flash when you get on it.
Chris
Old Jan 18, 2009 | 06:42 AM
FTICONVERTERS's Avatar
LS1Tech Sponsor
Also I would recomend a 3600.Go to our website and look at the SR series or the SST series.The SST series is alittle more aggresive(more for full competition) and the SR for street use. FTIconverters.com
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
