Circle D - NEW - 4L80 Multi Disk - Billet
Old Jan 23, 2009 | 06:34 PM
Circle-D's Avatar
Originally Posted by Randy WS6
I got my stageIII, 4L80 4400stall multi disk, Very nice piece of work. People that Ive showed it to cant believe the workmanship that was put in it ,Thanks Chris.
Thanks Randy, and your welcome. No go try and break it!
Chris
Old Jan 26, 2009 | 07:09 AM
98transguy's Avatar
Chris,
How would the 3 disc work with a rossler trans brake?Turbo car
Old Jan 26, 2009 | 09:36 AM
Randy WS6's Avatar
Chris
Ill try my best.
Old Jan 26, 2009 | 02:54 PM
Randy WS6's Avatar
Chris, Do i need to add fluid to the torque for amount of time to presoak the clutches. I know ill need to add fluid before installing it in the tranny, but do i need to add and let it set for a while to soak the clutches and what brand do you recommend i use in the torque and tranny new rebuild.
Thanks,Randy
Old Jan 26, 2009 | 03:22 PM
Circle-D's Avatar
Adding a little fluid is a good idea. I recommend what ever the trans takes. I would put about a quart and roll it around.
Chris
Old Jan 26, 2009 | 03:40 PM
red83's Avatar
From: sneaking in your back door as you leave!/cartersville ga
i have always ran non-dexron fluids as they have slip inhibitors
type f if its a fresh rebuild
Old Jan 26, 2009 | 05:30 PM
Randy WS6's Avatar
Does any body use the B&M trick shift tranny fluid ,or it worth it.
Old Jan 26, 2009 | 05:32 PM
red83's Avatar
I was told it is essentially type f. I ran it in my turbo car
Old Jan 27, 2009 | 10:02 AM
Circle-D's Avatar
Originally Posted by 98transguy
Chris,
It should work just fine. Manual lock-up switch or computer controlled?
Chris
Old Jan 27, 2009 | 10:24 AM
98transguy's Avatar
BS3 controlled lock up
Old Feb 8, 2009 | 11:18 AM
Circle-D's Avatar
A little bump - make sure everyone has seen it!
Chris
Old Feb 9, 2009 | 07:39 PM
  #32
rcsfastmonte's Avatar
please pm me I have some questions for you,i am looking to put a 4l80 in the twin turbo GTO.
Old Apr 21, 2009 | 07:58 AM
  #33
Circle-D's Avatar
Bump, back to the top for everyones enjoyment
Chris
Old Apr 21, 2009 | 09:24 AM
  #34
Avengeance's Avatar
Cant wait to get my 4L80e from FLT with the 4C in it!
