94 tranny in 96 car
Old Jan 27, 2009 | 06:47 PM
nasty96's Avatar
Default 94 tranny in 96 car
anyway to make a 94 obd1 tranny work in a 96 obd2 car?? have installed tranny and it has problems
Old Jan 27, 2009 | 06:52 PM
performabuilt2's Avatar
LS1Tech Sponsor
what problems the 94 to 96 have diffrent lockup strategy...the best thing to do would be a valve body swap and you need to get a 95 up converetr which has the carbon fiber lockup clutch for the PWM lockup
__________________
https://ls1tech.com/forums/image.php...ine=1194732633
Free Cooler, Free shipping always, 2 year warranty Trans/Coverter combos, No Core or Core charge, $150 LS1 core buy back, All trans Dyno Tested to Be sure it works when you get it.Customer videos, Tech Thread, Open 7 Days a Week! Call or http://opi.yahoo.com/online?u=performabuilt&m=g&t=2Click Banner for Website.
Not Just Built.....PerformaBuilt!
Old Jan 27, 2009 | 07:31 PM
performabuilt's Avatar
LS1Tech Sponsor
Actually you can simply swap the PWM solenoid and the 3-2 solenoid along with the wiring harness trans internal from the 96 to the 94 unit,
The PWM will act as a dunny to fool the PCM but the lockup will still work in a simple on of maner just as if you had eliminated the PWM in the 96
The 3-2 strategy and solenoid is a little different but from actually doing this myself and driving I have found no notable difference in the driving shift or feel.
But you must have the the 96 PWM and 3-2 solenoid there for the PCM to act properly.
Ideally its best to have the correct trans for the car but since its already in there this would be the route I would go and it should work just fine
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jan 31, 2009 | 09:35 PM
nasty96's Avatar
thanks alot performabuilt.. you talking about the wire harness inside the tranny or the engine wire harness?? and does it matter if i have a obd1 pcm ??
Old Jan 31, 2009 | 10:31 PM
LS1Tech Sponsor
The harness inside the trans needs to match the model year of the car,
__________________
Call 888-744-6542
