Missing Bellhousing Bolts . . . Problem?
Old Jan 29, 2009 | 12:25 PM
melsue's Avatar
Question Missing Bellhousing Bolts . . . Problem?
Would it really affect anything to leave the top 2 bellhousing bolts out on a trans install as long as the other 6 are in tight?
Old Jan 29, 2009 | 12:26 PM
z28mccrory's Avatar
I left the top one out and never had issues.
performabuilt's Avatar
LS1Tech Sponsor
Well its certainly best if you get them all in, However I will say GM ran the transmissions with only 6 bolts for many years
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jan 29, 2009 | 06:12 PM
forcd ind's Avatar
we used to just run 4 in a racecar, the last 2 lower ones on each side(vert.)
never saw a problem with it, but i wouldnt rec it-most gen 3 engines only get 5 if using a 350-400, or older 4l80e
the lower ones are the most important, as theirs no support bet. the engine/trans mounts, it would want to sep. if it could
