second drive
Old Jan 29, 2009 | 03:42 PM
ChevyRyda99LS1's Avatar
Default second drive
anyone know whats the purpose of the second drive in that a4 I have a 99z I always wondered what the drive after the OD was for, like when would you use it. This guy at a tranmission shop told me to use that in stop and go and in the city driving it helps your mpg.
Old Jan 29, 2009 | 03:53 PM
performabuilt's Avatar
LS1Tech Sponsor
It disables 4TH gear and allows overun or engine braking when decel , For normal driving there would be little point in using it . However for instance coming down a mountain it can help to slow the car some and towing it would help support the input sprag by turning on the overun clutch.
I do not see how it would save gas even around town in fact I would think the oposite
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jan 29, 2009 | 04:07 PM
camaroIroc's Avatar
yeah what he said^^
Old Jan 29, 2009 | 07:59 PM
01ssreda4's Avatar
yeah dont use it unless you know its helping....otherwise the trans might say **** it and take a **** on you.
Old Jan 29, 2009 | 08:26 PM
BadBandit69's Avatar
1 is first gear/ 2 is second/ D is third/ OD is fourth. in a 4th gen the selector allows you the choice of any gear the trans has. You would use 3rd for the reasons already stated above. You would prolly manually select D as often as you would 2 or 1= not often
