PerformaBuilt upgrade flywheel?
Old Jan 30, 2009 | 07:51 PM
bad98camaro's Avatar
Default PerformaBuilt upgrade flywheel?
PerformaBuilt do i need to upgrade my flywheel when i get my level 3 tranny
Old Jan 30, 2009 | 08:01 PM
performabuilt's Avatar
LS1Tech Sponsor
Thats up to you they are not that expensive so if its in your budget why not,
We dont carry flex plates though
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jan 30, 2009 | 08:13 PM
whats a good flywheel to go with the transmision?
Old Jan 30, 2009 | 08:18 PM
LS1Tech Sponsor
Several companies offer good ones I think TCI is pretty good though i realy have not had much expereince with them ,
__________________
Call 888-744-6542
Old Jan 30, 2009 | 08:39 PM
koolaid_kid's Avatar
I have a TCI flexplate, it is a fine quality unit and is SFI certified.
BTW, standards have flywheels, autos have flexplates. Just an fyi.
Old Jan 30, 2009 | 08:43 PM
GM LS1 168-Tooth Internal Balance Flexplate from TCI is that the one?(koolaid kid)
Old Jan 30, 2009 | 09:56 PM
That would be the one, part number 399753.
Be sure and replace the bolts with ARP bolts, they are fairly inexpensive. You'll need the 6 pack, of course. Of bolts and Bud, most likely.
Old Jan 30, 2009 | 10:12 PM
yes thinks alot part #399753 Price: $236.94 at TCI
 Michael S. Palmer
Old Jan 30, 2009 | 10:26 PM
ARP bolts (m11x1.5) the Pro series 244-2901
Old Jan 31, 2009 | 12:27 AM
cals400ex's Avatar
i was thinking the bolts that fit the factory stall are m10 x 1.5. with the tci flexplate you will definatly need longer bolts because that flexplate is thicker. i am not exactly sure what size bolts fit the performabuilt stall.
Old Jan 31, 2009 | 08:10 AM
Not sure on the flexplate bolts. They (TCI) don't claim it needs different bolts.
And you are correct, he should replace the TC bolts as well. IDK why they would be different from stock, but Frank should know on both, he knows his stuff.
A non-sponsor (rhymes with "plummit") has the parts for less $$.
Old Jan 31, 2009 | 12:29 PM
cals400ex's Avatar
i do know the torque converter bolts on the tci stalls are a little larger than the stock ones. i am thinking they are 7/16" if i remember correctly. my yank uses 10 mm ones.
