4l80e shift kit ? about the check balls
Old Feb 1, 2009 | 01:02 AM
jakeshoe's Avatar
The old HD2 kit had you doing mods to the stock plate, the newer one comes with a plate, you just drill the feed holes to your desired size and go.
Much easier to install the newer one and minimizes drilling on the VB.
I don't use the HD2 kit anymore when building a trans but it will work well for you.
Old Feb 1, 2009 | 01:06 AM
jakeshoe's Avatar
Did do what,
drilling the hole for full time lube?
It's good on towing rigs that maybe at or near WOT for extended periods of time.
It can be problematic in some applications because the converter charge pressure gets too high and can cause engine thrust bearing damage from the converter pushing forward into the crankshaft.
It's a common issue on TH400's, and the full time lube mod can make it worse, as well as aftermarket input shafts, excessive line pressure, etc.
There's not as much time on the 4L80Es in performance applications to see the common issues we've had 40 yrs to find on a TH400.
Old Feb 1, 2009 | 02:04 AM
hawkls7's Avatar
Jake , i installed the old hd2 kit , now i heard there is a newer one . Any way there was a mod im sure i did to the pump and that was drilling a hole which was on the instruction sheet with the pump picture . I m becoming woried about it . I recently had a faulty 3-4 solenoind that became faulty after several dyno pulls , we lost 3rd and when i inspected trans i noticed that the 4 metal lugs that hold the plastic tangs became very loose and could not operate any more so i changed it to a new one and then it had 3rd gear again.Could this mod cause such a thing. I have spent alot of money on all the best parts available, you name it i brought it
Old Feb 1, 2009 | 03:01 AM
jakeshoe's Avatar
Sounds like a faulty solenoid and nothing more, the full time lube mod will not cause a sol failure.
It is a sound mod in theory but in SOME applications it can cause problems.
It is the same mod used on the TH400, and for the same effect.
TH400's are known in some cases, particularly with fixed line pressures (full manual valve body), to have excessive converter charge pressure.
This forces the converter forward into the engine, taking out the thrust bearing.
Good builders do pump mods to slightly restrict converter charge flow (and effectively pressure) on TH400's that fall into the likely category (fixed line, certain engines with weak thrusts, etc)
I haven't really paid attention to the possible restrictions on the out side of the converter to see if it might be an common issue on a 4L80E too, but I haven't heard of any issues. Although not too many 4L80Es running around with fixed line pressure either... I have a few that way though I know Trinity does as well.
Old Feb 1, 2009 | 03:50 AM
hawkls7's Avatar
Are you saying its ok , wait and see ! . I had a squirt on the road the other day , but not on full power i only slowly put my pedal down just to get a feel of the power . the engine has not been fully tuned and the car is not responsive until about 4500 rpm but i can tell you this is when it shifted from second to third it was verry firm , the car pulled to the left , the trans felt very strong and shifting is very direct, i have the blue plate frictions and the colene coated steels. the box is not a full manual , i can to install the pcs controller because there was no way that the tcm42 ls system could work. My tuner has just informed me that we need to put a manual to tune because on the dyno the yank py converter is stalling to 5500, and it is becoming unsafe to tune. one thing for shure is at least i will know the real hp using this method thanks any thoughts .
Old Feb 1, 2009 | 06:47 AM
forcd ind's Avatar
i have an old hd-2 kit that was never installed, i wonder if i could get the updated sep plate for it from TG
i noticed on the 2005 unit i built(or tried to anyway) it had the updated "thick" snap ring from the factory that they give you in the kits, along with some other stuff
Old Feb 1, 2009 | 09:49 AM
FLT's Avatar
FLT
I think the issue with full time lube in an 80 is not a problem. I did this mod on Parish's blue truck and it was not a problem as far as I know. (1000+rwhp) Now in a 400 if a trans brake is being used I understand Jakes point here and agree. When the brake is applied the transmissions line pressure is very high. The full time lube mod is tapped into the line pressure circuit so I see the point in not doing this with a trans brake. Vince
Old Jun 19, 2011 | 08:32 PM
Tootall's Avatar
bump for looking for old info . . .
pulled my trans appart and found an extra check ball that wasn't in the directions. . . .
4L80e 8th check ball, leave out, take out check ball
Old Jun 28, 2011 | 01:50 PM
slow67's Avatar
Gingervitis Addict
Picture of where it was?
Old Jun 29, 2011 | 08:35 AM
forcd ind's Avatar
sh 5 also shows the ball placement, they only use 7, as noted on the instructions
i noticed some later trans seemed to have the heavier snap ring installed from the factory
