4l80e speed sensor
Old Feb 3, 2009 | 01:18 PM
forcd ind's Avatar
Default 4l80e speed sensor
i was hooking up my Abbott speedometer converter, and it says to hook up 1 wire to the sensor, and the other ground, and +12
it shows the sensor as an output, and ground-i cant tell which contact is which-i tried an ohm meter, fig if one was grounded, i could tell from the meter, but it just shows both leads as open-does it matter which is grounded?
i think the sensor is just an induction coil?, but the gm wiring shows it like there is a diff, hi sig and low sig
Old Feb 3, 2009 | 02:12 PM
tptransmission's Avatar
Closed ex-Sponsor Account
Pin "A" at the sensor is normally the 5 V reference voltage from the controller. B is to the ground.
Old Feb 3, 2009 | 02:53 PM
forcd ind's Avatar
as im looking at the drawing, is the top or bottom pin "A"-i cant see up in the trans tunnel if its marked a or b on the sensor, kind of tight
the sensor is actually 180 degs from the pic, looking from the back of the trans, so its easier to just go off your drawing, top or bottom
thanks
i hope this motor driven converter isnt to loud, as its gonna be under the dash
of course i cant hear the radio, so prob couldnt hear this thing either, lol
Old Feb 3, 2009 | 06:34 PM
Should be the front one. The common wire for input and the output sensors is the same color so the other should be pin "a"
Old Feb 3, 2009 | 06:49 PM
forcd ind's Avatar
ok i was able to get the plug off(bought it off ebay with a short pigtail) it has a & b on the plug, a has a purple wire and b is yellow-so i;ll hook up the sdr wire to the purple and gnd the yellow, then run it thru its cal. and see what happens
thanks
