LS1/4L60E problems
Old Feb 3, 2009 | 09:36 PM
wildcatcamaro's Avatar
Default LS1/4L60E problems
I know I'm still in the process of working out the bugs from the swap, but maybe you guys can tell me what's going on with it.
The last time I was driving my Camaro it was doing some weird things. When I would go to pull out, it would jerk around (no matter how much I gave it gas, it wouldn't go, then it would catch, then not, repeat). I think it might be something with the transmission. I checked the fluid, and I believe it's fine. I'm not sure, but I think the trans has a stall converter of about 1500-2000rpm. Then again, I still have electrical gremlins that keep showing up, and when I pulled it out during Christmas break, I discovered a gas leak somewhere over the rear end...I guess one thing at a time.
I just need to know if this is a transmission problem or something else.
Old Feb 3, 2009 | 09:45 PM
performabuilt's Avatar
LS1Tech Sponsor
The fuild wasa good place to start . But if you have electrical gremilns they may very well be the source of your issues they need to all be addressed first before you can make any determination,
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Feb 8, 2009 | 03:38 PM
Does anyone know someone who's good with electrical stuff in the middle tennesse/north alabama areas? I think i know someone who could tell if the trans is bad, but I gotta get it drivable for that
Old Feb 8, 2009 | 03:59 PM
FLT's Avatar
FLT
Go to the list of sponsors and enter you area code. Find one close to you and start there. Vince
