Trinity shift kit
Old Feb 6, 2009 | 11:47 AM
forcd ind's Avatar
Default Trinity shift kit
i picked up another 2004 4l80e, and this time i might try the TP man shift kit
was wondering what the insts. looked like, and the mods-can i keep a lockup converter, and my speedometer sensor(i notice they give you a plug for the conn.)
didnt have a lot of luck with the transgo kit, and dont want to cut up another v/b, lol
Old Feb 6, 2009 | 01:26 PM
tptransmission's Avatar
Closed ex-Sponsor Account
You can leave the pass-thru in place to run a lockup converter. The plus is optional. Are you wanting just a Manual v.b. kit or a t-brake also? The speed sensor is not changed from its external location.
Old Feb 6, 2009 | 02:07 PM
forcd ind's Avatar
man shift only
Old Feb 6, 2009 | 02:58 PM
just leave you wiring in place if you want to run a Lock up converter. Also if you decided to go computer controlled later on you can use the same v.b. there is no drilling required.
