4l60e output shaft play??
I searched and found one other post that said having this much play was normal, but that just seems so wrong to me. you can hear it clunk inside the trans if you wiggle the output shaft around.
I guess my highspeed driveline vibration must be caused by the driveshaft. Its just a re-balanced shortened stocker. Guess its time for a custom shaft that will handle the RPM, this one must not be good enough.
