new 4l80e press test w/wo mod
Old Feb 9, 2009 | 07:13 AM
forcd ind's Avatar
Default new 4l80e press test w/wo mod
im making some progress on the trans, 4l80e w/man shift kit, but
w/o mod, 1200 rpms
P-165
R-170
N-165
D-60
3-95
2-100
1-95
w/mod, 1200 rpms
P-105
R-150
N-105
D-55
3-85
2-90
1-80
the pressure goes up with rpm's as it should, 175 depending on what gear, but i still have a delayed 2-3 shift-i also noticed that the engine seems to labor some above 4k rpm's, almost like the trans is fighting it a little, but kind of hard to tell-i think the winter blend for the fuel is leaning out the motor a little, i think, the supercharger doesnt like it, may add some 110-i dont have anything to ck the pressures against, so does it seem normal-my book doesnt list any pressures, but the book for 400's lists higher pressures
i may pull it down, tighten up the clutch packs, rem inner seal on the direct?
Old Feb 9, 2009 | 09:52 AM
performabuilt's Avatar
LS1Tech Sponsor
Still not right with the mod unhooked you should see something near max line at idle in drive 175 to 235 psi
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
