converter of choice
Old Feb 11, 2009 | 06:51 PM
TXCAMSS's Avatar
"All Motor 9 Second club member"
Circle D all the way!!!
I run their 4C in our mid 11 second SS and their 8" race converter in our low 9 second SS. I have data logged many converters and I've seen the TC internals of some of the top converter builders out there and there are several good reasons why I will stick with Circle D for my converter needs.
Don't take short cuts in the torque converter department.
Old Feb 11, 2009 | 07:01 PM
454mag's Avatar
Whatever you do dont cheap out on the converter. My SS is on its 7th converter. After mucho research and time on the phone with various manufacturers the only two choices for me came down to FTI and circle D. I just finished my FTI install and the car feels great but its kinda tough to test a 4400 stall with snow and ice on the roads. Cant wait till the track opens in april. The smaller guys will take the time to build what you want not sell you an off the shelf one size fits all.
Old Feb 11, 2009 | 07:13 PM
datz kool's Avatar
Call Lenny Croteau at ultimate convertors, One of the best in the business...........
Old Feb 11, 2009 | 08:44 PM
Camaro396's Avatar
That's what I run.
Old Feb 12, 2009 | 05:52 AM
troopercar's Avatar
Of any of the top brands (Yank, Precision, Circle D, FTI) you will only be truly impressed with the converter if it is perfectly matched to the car and it's intended purpose. The more time they spend getting all the info from you (and the more accurate your answers) the better off you'll be.
If you had the wrong Circle D in the car that you bought used and swapped it for the correct TCI you would then think TCI rocks. (Until it takes out your tranny)
Old Feb 12, 2009 | 08:14 AM
datz kool's Avatar
Originally Posted by Camaro396
That's what I run.
The convertor is most likely the key componet of how your combination works, These things are strange beasts and are not fully understood by the average racer or street enthusiest,TO GET IT RIGHT THE FIRST TIME YOU NEED AN EXPERT ON THE RIGHT COMBO FOR YOUR APPLICATION.
remember it costs just as much time and money to get it wrong as it does to get it right.
454 mag, have you really gone thru that many convertors.Are you a victim OF THE TRICK OF THE WEEK SYNDROME??????
take care....
Old Feb 12, 2009 | 06:26 PM
454mag's Avatar
Yes have reallly had that many in the car. Actually only had one go bad. it was the first "performance" converter I bought and I went cheap and got a fuddle. It lasted less than 5k miles and took out my trans. He did send me a new billet verter for a few more bucks but I was all done with him.
As you stated it is one of the most important pieces of how your car runs at the track and I keep refining it a little more each time. I race heads up on a .400 pro tree so the verter is the difference between winning and losing. Instead of hijacking this post I will start a new one with reviews and pros and cons.
Old Feb 12, 2009 | 08:03 PM
JunkyardZ's Avatar
already been mentioned,,, yank..pt4k!!
Old Feb 13, 2009 | 12:27 PM
Bad30th's Avatar
Originally Posted by 01ssreda4
i like my edge converter. i believe all the sponsors here make a great product as well.
+1 for Edge Racing converters. Mine has been awesome behind my 4L80E.
Rob (Bad30th)
Old Feb 13, 2009 | 03:15 PM
OddballLt1's Avatar
A friend of mine has a Yank 3600 SS in his bolton Lt1, and it lays over badly on the big end. Its 60' is awesome at a 1.77 but it falls of right after that.
Old Feb 13, 2009 | 03:30 PM
john563's Avatar
circle D 5c here and love it!! read my post on my thought on it
