what tranny fluid to use?
Old Feb 11, 2009 | 07:07 PM
meatyz's Avatar
Default what tranny fluid to use?
my trans fluid is low on my camaro ss because of a leak it had its a 4l60e with alot of work and 4,000 stall
Old Feb 11, 2009 | 07:33 PM
tptransmission's Avatar
Closed ex-Sponsor Account
depends on what you have in there. The factory fill is Dexron 3. If you used synthetic then you do not want to mix the two.
Old Feb 11, 2009 | 07:40 PM
meatyz's Avatar
im not even sure what they used when the build was done what would you usually use in a tranny like that?
