Help with transmission!!!
Old Feb 15, 2009 | 10:56 AM
bad98camaro's Avatar
Exclamation Help with transmission!!!
I installed my new tranny i put 3 cans of oil and it starts to over flow out if the tranny dip stick. it reads full but when i put it in drive it moves 3 feet and stops.
Old Feb 15, 2009 | 11:15 AM
performabuilt's Avatar
LS1Tech Sponsor
If you only put in three quarts thats not near enough, if its coming out the dipstick its possible the vent tube on the top of trans is blocked or crushed, This will prevent air from escaping and cause what you are experiencing.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Feb 15, 2009 | 11:21 AM
Soon as i pour the oil it comes out 5 sec later from the dip stick. The car is off.
Old Feb 15, 2009 | 11:39 AM
LS1Tech Sponsor
I would check that the small vent tube at the top of the trans near the bell has not become blocked or collapsed
__________________
Call 888-744-6542
Old Feb 15, 2009 | 12:14 PM
I will check on it and let u know
Old Feb 16, 2009 | 09:35 PM
TXCAMSS's Avatar
"All Motor 9 Second club member"
I agree.
I bet $$$ the vent tube is plugged off. Don't run the car until it takes fluid and shows a level or you'll burn it up. G/L
