Yank ST3500 problems
Old Oct 12, 2003 | 04:10 PM
jruss's Avatar
Default Yank ST3500 problems
I just had a used Yank ST3500 installed today . I have a few problems so far:
1)When I tach the car up to say 1700-2000 rpms it does nothing ! Feels like a damn trailer is hooked to the car...bogs so to say .
2)When I was sitting at a stoplight I felt two terrible jolts as if the car had been hit in the rear .
3)The car does not want to run dies out
I have LS1 Edit(done by MTI) on the car programmed for the stock stall and a MTI T1 cam,stock 3:23 gears .
My question is will reprogramming the car deal with these problems or is the converter BAD ? I'm LOST
Old Oct 12, 2003 | 05:36 PM
42NightZ28's Avatar
Default Re: Yank ST3500 problems
1 and 3 are normal. 1 is just the nature of a converter it should move a bit i would check your fluid if its not doing anything. 3 your computer will get use to it after a while and not die anymore. I have no idea about number 2.
Old Oct 12, 2003 | 08:51 PM
jruss's Avatar
ok if #1 is normal how the hell do you cut such good 60' times if it doesnt hardly move ? will tuning to a specific stall solve #3 ?
Old Oct 13, 2003 | 05:07 PM
BigPlanTransAm's Avatar
#1 the whole point of a converter is to slip you higher into your powerband so the reason it dogs is beacuase you feel it "slipping".
#3 the converter probably has a higher STR so there is always more fo a load on the motor which bogs it more than stock so it drops below its idle speed and dies.
#2 were you about to start moving or did you just stop? or was nothing at all going on? if nothing was happening i think something is wrong. i would talk to the guy who installed it.
Old Oct 13, 2003 | 06:35 PM
jruss's Avatar
I went to MTI to be retuned car runs fine BUT the tranny is SHOT The car wil no move in overdrive 1st gear is the only gear that moves the car period and can't go over 50mph due to rpms maxing out . The converter will not lock when I was able to go 70 mph it was tachhig over 3k rpms with 3:23 gears . Also the tranny fluid is brown or burnt in color . I feel I was sold a bad converter by a fellow LS1.com member . My only recourse now is to put stock converter in and hopefully GM will cover it under warranty . The Yank will have to be sent off for service .
Old Oct 13, 2003 | 07:00 PM
Ragtop 99's Avatar
If you bought a used converter, it is normally not a problem unless the converter came from a failed tranny. In that case it could have trash in the converter which then spread to your tranny.
The converter not locking maybe a programming issue.
Send the converter back to Yank for cleaning and inspection. I would also ask Mike about updating the clutch to the new material he is using now.
Old Oct 13, 2003 | 09:12 PM
Cheatin' Chad's Avatar
I'm not trying to be a dick here but if the tranny is hurt because of something you did why should GM cover it under warranty?
Things like this happy in this hobby and if your not willing to pay when **** goes awry maybe you shouldn't be involved in it. Fraudulent warranty claims are one of the reasons cars cost as much as they do.
Your best bet would have been to send the converter straight off to Yank before it was ever installed in your car.The responsibility lies with the consumer and pointing fingers is not going to help once the damage is done. With a little planning situations of this nature can be totally avoided.
Just my opinion
