How to hook up vacuum modulator?
Old Oct 13, 2003 | 03:04 PM
restorit's Avatar
Default How to hook up vacuum modulator?
I bought an 84 z28 with the l69 5.0 HO/4bbl - It was originally equipped with a 700r4, the guy I bought it from swapped in a TH400 from a 78 400sbc Blazer. well, driving it home i noticed it wont shift properly, i started ripping it apart for the 355 swap I had planned, and noticed the vacuum mod is not hooked up to anything. anyone know where to hook it up on these cars? I know the 700 is not vacuum modulated, is there even a place you can hook one up? any help will be appreciated.
Old Oct 13, 2003 | 04:09 PM
WILWAXU's Avatar
Default Re: How to hook up vacuum modulator?
T off the brake booster line.
Old Oct 16, 2003 | 11:32 AM
restorit's Avatar
I was told not to go off the brake booster. can you explain a little more so I can understand?
Old Oct 16, 2003 | 12:46 PM
WILWAXU's Avatar
Had mine hook to the brake booster for over a year without issues.
Basically I have a T in the booster line with large sides going into the booster line, and a small tip connecting a vacuum tube to the tranny.
Old Oct 16, 2003 | 12:51 PM
restorit's Avatar
Sounds good to me... Muchas Gracias
