Picking the right stall/ company
Old Feb 22, 2009 | 03:07 PM
blockheadnic's Avatar
Default Picking the right stall/ company
So trying to find the right TC and company has proven to be pain in my a$$. with so many opinions, and options out there i am at a lose as to which one to pick. so iam looking for help.
So with that being said,
The car is a 98 formula.
Weight 3000lbs
Trans th400 with red clutchs and kevlar bands, NO tbrake,
ci 346
ported ls6 heads
Fast 92/92
G5X3 cam or there about
Strip only
7k rev limit
15 by 10.5 drag radials, or slicks?
Race suspension.
150 N20 maybe
not looking to break the bank but want opinions from 600-1000 budget
Old Feb 22, 2009 | 06:17 PM
Randy WS6's Avatar
Call Cercle-D , they fixed me right up and will you to
Old Feb 22, 2009 | 06:45 PM
well maybe they can chime in.
Old Feb 22, 2009 | 07:02 PM
01ssreda4's Avatar
i went with an edge converter....
Old Feb 22, 2009 | 07:40 PM
TurboAv's Avatar
FTI hooked me up for a very reasonable price on my TH400 converter. Drives tight on the street but wack the throttle and look out. The thing that really impressed me with their converter was that I went from a six speed setup trapping 115 to a TH400 setup trapping barely less at 114.13. That's one damn efficient converter. I will say I chickened out and went with a 4000 NA stall. Greg said it should stall 600-800 higher on a 150 shot for me. I know wish I would have gotten a 4500-4800 NA stall. Once it heats up here in Phoenix I'll send it back for a restall.
Old Feb 22, 2009 | 07:46 PM
9000th01ss's Avatar
With a th400 I always had good luck with a TCI off the shelf.
Non lock up converters are easier than lock up converters, being that the main difference is lock up clutch durability, etc.
Without the lock up, I'd be inclined to say that every manufacturers builds are probably damn near identical.
So that leaves it up to talking to a converter builder and getting one to build you a converter that will have the driving characteristics you're looking for.
It would be ideal if someone called every converter manufacturer and gave them specs for one car. Then just spent a few weeks swapping converters and testing the results and seeing who came the closest.
Obviously that never has happened so it's a coin toss. Pick one and go with them.
Old Feb 22, 2009 | 08:01 PM
Circle-D's Avatar
Picking a torque converter company can be very difficult, especially for a non lock up. A lot of options. I think Circle D can meet your needs, do it for a reasonable cost and be here if you ever need us. Looking at your specs, I would suggest our new 230MM billet converter. It will footbrake great for you and pull through the quarter. I will shoot you a PM with more details.
Chris
Old Feb 22, 2009 | 10:43 PM
Chris
You got mail.
Let me know what you think would work best for my setup.
Old Feb 22, 2009 | 10:54 PM
Detoxx03's Avatar
Look into Yank
Old Feb 23, 2009 | 05:28 PM
FTICONVERTERS's Avatar
LS1Tech Sponsor
If you are looking for a true race converter I can help.Our converters have won national championships,been low qualifier,etc.We build real performance converters from street converters to bolt togethers for 2500 hp to the car that won at US Nationals last year.
I would recomend a 8".Part # SS895. Look at our website under SS series competition converters.We also offer this converter with a steel stator or a mechanical diode.
Give me a call or pm me.1-866-726-8358
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Feb 23, 2009 | 06:38 PM
streetassasin's Avatar
another vote for circle d, I have only had mine in for a little bit but its a badass piece
Old Feb 23, 2009 | 07:46 PM
CoolAid's Avatar
Havent got to play with my Circle D +4C yet, but I can vouch for their beyond top notch customer service and support. A+
Old Feb 24, 2009 | 06:48 PM
Cape T/A's Avatar
ill be ordering and edge stall this week, 5 of my friends are running an edge stall in their 4l60e's without problems.
Old Feb 24, 2009 | 06:55 PM
heymoej's Avatar
i have had yank & vig with out any complaints........i hear circle d is kick *** toooo.
Old Feb 25, 2009 | 12:43 AM
TXCAMSS's Avatar
"All Motor 9 Second club member"
Yes sir! Circle D is kick ***. No question there.
I currently run their 230mm race converter in our car in the powerglide. I also ran the 230mm in the same car when we had the 4L60E in it. We managed to pull 1.29 60fts with both set ups and they both proved to be very efficient down the track.
