4L60E vent
Old Feb 26, 2009 | 04:14 PM
my number 1 hater's Avatar
Default 4L60E vent
On top of the 4L60E there is a vent line(im guessing) and a small vac check valve. does it really need the check valve or can i just put a piece of vac hose on it and go.. Also what would the check valve be for???
Old Feb 26, 2009 | 04:17 PM
performabuilt's Avatar
LS1Tech Sponsor
The check valve is to keep water etc from traveling back up the tube. If you dont live in and area where you will be in any deep water or puddle or high mosture areas its probably fine without it. Well unless the car sets a long time then i have noted that dirt dobbers like to make nest in them .
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Feb 26, 2009 | 05:06 PM
Cool good to know..
