4l80 in camaro
Old Feb 26, 2009 | 05:10 PM
firebird355's Avatar
Default 4l80 in camaro
what all do i have to get and also modify to make a 4l80 work in my 98 camaro with a 4l60
Old Feb 26, 2009 | 08:45 PM
Silver_TransAm's Avatar
Wire adapter harness
a new crossmember
a 1350 u joint conversion
a flexable dipstick
a 4l80e convertor
a cut off wheel and a big hammer
Just did it not to long ago
Old Feb 26, 2009 | 09:44 PM
Camaro Ken's Avatar
What is the difference in location for the x-member i'm considering doing this for my 71 ls1 conversion. Are there as many converters readily available for these trannies?
Old Feb 26, 2009 | 10:33 PM
tptransmission's Avatar
Closed ex-Sponsor Account
71 is a totally different you do not have to worry about a torque arms etc. You will need to modify or reposition the crossmember. Get a driveshaft made and come up with a way to control the transmission. We can set you up with a full manually shifted valve body or a After market controller which I can assist you with. PM me and we can help you.
