FLT have a tech question for ya
Old Mar 1, 2009 | 08:24 PM
MattysTA's Avatar
Default FLT have a tech question for ya
i picked up a cheap 99' 4l60e core to rebuild for my car. the previous owner told me it wouldnt shift outta first. it was built in 05' has 5 pinion planetarys,beast shell,billit servo and red clutches,red wideband. upon tearing it down i found some metal pieces which came from the input shaft drum retaining ring tabs. in your opinion what is the possible cause for this to happen? Thanks
Old Mar 1, 2009 | 10:21 PM
FLT's Avatar
FLT
Normally when I see a drum failure the first thing that comes to mind is a harsh 3rd gear shift. A few things can cause this. Excessive transmission line pressure. 3rd gear feed hole being to large. Excessive clutch clearance. 3rd accumulator being eliminated by the use of a solid billet 2nd gear servo. Pressure spikes caused by a worn pressure regulator circuit. As I mentioned many things can cause this. Good luck with your build. Vince
Old Mar 2, 2009 | 08:26 PM
PedaltoMetal's Avatar
scrap it and send the rear planet to me
