4l60e problem - Help!
Old Mar 1, 2009 | 11:03 PM
donkey mule's Avatar
Default 4l60e problem - Help!
I have a 1995 trans am with a 4l60e. It is doing something very odd that I need advice on. When I am driving the car and it starts to go into OD the car shakes and feels like I hit a rough patch on the road. It only does this when driving with restraint. When I get on it or go into OD when the rpm's are a little higher there is no signs of the shaking or rough feeling. Any of ideas?
Old Mar 1, 2009 | 11:33 PM
performabuilt's Avatar
LS1Tech Sponsor
are you sure its not the converter locking?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Mar 2, 2009 | 02:26 AM
9987ta's Avatar
Might be what they call convertor sudder from worn valve bores in the valve body.
Old Mar 2, 2009 | 08:31 AM
I guess it could be the converter locking. Its just not done this before, Is this a big problem?
Old Mar 2, 2009 | 01:38 PM
LS1Tech Sponsor
You might try raising the lockup point what type converter is it ?
__________________
Call 888-744-6542
Old Mar 3, 2009 | 07:39 AM
Its an Edge Racing 3300 stall.
