Quick convertor questions
Old Mar 3, 2009 | 09:09 PM
sman's Avatar
Default Quick convertor questions
Im putting a v8 in my v6 fbody and have a TLBK converter at my disposal, I was wondering what the stall speed on this is? Also, I was suggested to try a Trailblzer SS converter, as its an inch smaller and should have a slightly higher stall speed. What are your thoughts?
Old Mar 3, 2009 | 11:10 PM
sman's Avatar
I thought I seen a bit of info on here one time that showed the stock stall speeds for the converters, but I searched and searched and just cant seem to come up with it.
Anyone run a TBSS converter on there ls1? What does it stall? What did you pay for it? Did you encounter any issues?
Old Mar 3, 2009 | 11:31 PM
LS1_K1DD's Avatar
^I can't imagine it would be much higher than an LS1 converter. If your going to pay for it, might as well just buy a Yank/Vig/Circle D and get it right the first time. Don't forget a cooler.
Old Mar 3, 2009 | 11:32 PM
sman's Avatar
Doing some more searching, I guess people are using the I6 trailblazer converter NOT the TBSS. Does this bolt up to the ls series of motors without problems? What stall does it yield.
EDIT: The i6 TB converter can commonly be had for about a $100. And EVERYTHING is apart now, just waiting on this stuff to put the motor/trans back in.
Old Mar 3, 2009 | 11:56 PM
chevyz2801's Avatar
pm sent
Old Mar 4, 2009 | 07:55 AM
Circle-D's Avatar
The TBSS converter is basically the same as the converter in the LS's cars. You are correct, it is the TB I6 converter that is smaller, 11" vs 12". I sell a modified version of the TB. I use a HD clutch, tig weld, and HD bearings. Up the stall to 3000-3200. They make a great replacment for a street car. Here is a link.
I offer Tech members a special price - PM if interested.
http://www.circledspecialties.com/Co...s/LS1-278.html
Chris
