Help New trans/converter wont hold fluid
Old Mar 6, 2009 | 06:17 PM
streetassasin's Avatar
It has a brand new speedInc plate that went in the same time as the trans and converter
Old Mar 6, 2009 | 07:09 PM
performabuilt's Avatar
LS1Tech Sponsor
Well also I have seen this install error.
If you use the bolts to pull the converter to the plate rather than having the converter flush against the plate it can create the same wobble affect and of course it could have just happened. I have seen it before happen with no real explanation I could find.
Now also consider if there is any blueing on the converter hub where it meets the bushing you should also check for cooler restriction either in the lines or the cooler it self.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Mar 9, 2009 | 12:29 PM
Originally Posted by 99Hawk262
Sorry to hear about your luck, it happens man....could have been worse though. When I fried my last tranny, the car was down for about a month . Hopefully it's not too bad internally. On the bright side, it looks like Xtreme trans and Circle D are taking good care of you. We're very fortunate to have the wonderful sponsors we have!!
x2 on sponsors, I would be completely screwed if this happed from a trans built locally
Old Mar 9, 2009 | 03:51 PM
GreatWhiteZ28's Avatar
want to bet? Bakers took greta care of me when mine popped a ring out of place and caused it to lock up, rebuilt it for free even after the warranty had expired and got it done it 2 days, that's dropping it off at 3p.m. on day one and picking it up done and ready to go at 5p.m on day two....
anyways back on topic...welcome to the world of fkin with your DD..Shouldn't have picked on me back when my Z was my DD and when it was broke.. it's all good though bro...soo when you gonna bring the Red Sled by to keep mine company for a weekend???? glad you got the trans issue taken care of
Old Mar 10, 2009 | 01:56 PM
Just got back from the trans shop and found out what the problem was, the bushing wasn't loctited in and walked out. But it looks like Xtreme is taking care of it
James should be calling you soon Jonny
Old Mar 10, 2009 | 02:10 PM
9000th01ss's Avatar
Bushings don't need to be loctited in. Thats usually done for reasons I won't say. But it's not a common practice to install a converter and take the bushing out to loctite it in place.
That may solve the problem, but thats not what caused the problem.
