Need input FAST !! Tranny in limp, not working
Old Mar 7, 2009 | 11:18 AM
3800RS's Avatar
Default Need input FAST !! Tranny in limp, not working
I just swapped the ls1 a4 in my car. The tranny doesnt seem to be shifting. I believe it to be in limp. Kinda starts in 2nd gear and doesnt really shift. Speedo is not reading either. Pin "E" at the round trans connector has 12v when the key is in run. Cant figure this out for the life of me. Someone please infor me. I have a maf p0102 and a p0118 code. Not sure if they are related.
Old Mar 7, 2009 | 11:56 AM
performabuilt's Avatar
LS1Tech Sponsor
Well I would suspect a wiring issue or or blown fuse.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Mar 7, 2009 | 12:24 PM
3800RS's Avatar
tranny has power at pin e though
Old Mar 7, 2009 | 02:28 PM
LS1Tech Sponsor
There are fuses to other components. That can affect trans, And for shifting the speedo is a must have also. If you have a way to look at data you could probably tell alot, I would start with the speedo myself and go from there.
__________________
Call 888-744-6542
Old Mar 7, 2009 | 04:15 PM
3800RS's Avatar
what could not be getting power ? I can go with a volt meter and a continuity tester if you give me some direction.
Old Mar 7, 2009 | 04:22 PM
Jscotty's Avatar
P0102 = Mass Air Flow (MAF) Sensor Circuit Low Frequency
P0118 - Engine Coolant Temperature (ECT) Sensor Circuit High Voltage
It is most likely the wiring. I'm not the most savvy with the electrical systems on these things. I'll send a PM to someone I know who is. I'll have him check out this thread.
Old Mar 7, 2009 | 04:30 PM
3800RS's Avatar
i fixed the ect code and i believe the maf is fixed too. Still no shifting or speedo though.
